thinkgeo.mapsuite.core.jpeg2000rastersource
ThinkGeo.MapSuite.Core.Jpeg2000RasterSource
This class represents the JPEG2000 raster source.
    • ThinkGeo.MapSuite.Core.RasterSource
      • ThinkGeo.MapSuite.Core.EcwRasterSource
        • ThinkGeo.MapSuite.Core.Jpeg2000RasterSource
Jpeg2000RasterSource()
  • This is the constructor for the class.
Jpeg2000RasterSource(String)
  • This constructor gets the RasterSource ready to use.
  • imagePathFilename
    • Description:This parameter is the path and file name of the file you want to use.
Jpeg2000RasterSource(String,String)
  • imagePathFilename
  • worldFilePathFilename
    • Description:This parameter is the path and file name of the world file you want to use.
Jpeg2000RasterSource(String,RectangleShape)
  • imagePathFilename
    • Description:This parameter is the path and file name of the ECW file you want to use.
  • imageExtent
    • Description:This parameter is the image extent of ECW file you want to use.
CloneDeep()
GetWorldFileText()
GetImageWidth()
GetImageHeight()
GetHorizontalResolution()
  • Type:Single
GetVerticalResolution()
  • Type:Single
GetBoundingBox()
GetProjectionText()
Open()
Close()
GetImage(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
GetProjectionTextCore()
GetImageWidthCore()
GetImageHeightCore()
OpenCore()
CloseCore()
GetImageCore(RectangleShape,Int32,Int32)
  • canvasWidth
  • canvasHeight
GetBoundingBoxCore()
OnOpeningRasterSource(OpeningRasterSourceEventArgs)
OnOpenedRasterSource(OpenedRasterSourceEventArgs)
OnClosingRasterSource(ClosingRasterSourceEventArgs)
OnClosedRasterSource(ClosedRasterSourceEventArgs)
CloneDeepCore()
GetWrappingImageLeft(RectangleShape,Double,Double,RectangleShape)
  • screenWidth
  • screenHeight
GetWrappingImageRight(RectangleShape,Double,Double,RectangleShape)
  • screenWidth
  • screenHeight
PathFilename
Projection
Transparency
  • Type:Single
BlueTranslation
  • Type:Single
RedTranslation
  • Type:Single
GreenTranslation
  • Type:Single
IsNegative
IsGrayscale
IsOpen
HasProjectionText
HasProjectionTextCore
OpeningRasterSource N/A
Event Arguments:OpeningRasterSourceEventArgs
OpenedRasterSource N/A
Event Arguments:OpenedRasterSourceEventArgs
ClosingRasterSource N/A
Event Arguments:ClosingRasterSourceEventArgs
ClosedRasterSource N/A
Event Arguments:ClosedRasterSourceEventArgs
thinkgeo.mapsuite.core.jpeg2000rastersource.txt · Last modified: 2017/03/16 21:59 (external edit)
