thinkgeo.mapsuite.androidedition.currentextentchangingmapvieweventargs
ThinkGeo.MapSuite.AndroidEdition.CurrentExtentChangingMapViewEventArgs
Use to send data when map's extent is changing.
      • ThinkGeo.MapSuite.AndroidEdition.CurrentExtentChangingMapViewEventArgs
CurrentExtentChangingMapViewEventArgs()
  • Initializes a new instance of the class.
CurrentExtentChangingMapViewEventArgs(RectangleShape,RectangleShape)
OldExtent
  • Gets or sets the old extent.
NewExtent
  • Gets or sets the new extent.
thinkgeo.mapsuite.androidedition.currentextentchangingmapvieweventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
