map_suite_mvc_edition_background_maps_google_bing_etc._samples
Map Suite MVC Edition Background Maps (Google, Bing, etc.) Samples
ArcGISServerRestOverlay
In this web-based project, we'll demonstrate the new ArcGISServerRestOverlay released with Map Suite 5.0 WebEdition. This overlay gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new overlay utilizes the ArcGIS Server REST API. You can also check out the sample video to see the ArcGISServerRestOverlay in action.
Custom Map with Google Labels
screenshot
GPS to Google Map(Web)
Great Circle with Google Map
Mini map with Google Map
OpenStreetMap
Shapefile to Google Map
map_suite_mvc_edition_background_maps_google_bing_etc._samples.txt · Last modified: 2015/10/10 07:31 (external edit)
