<!– Class –> This class represents the base class of map tools.
*System.Object ThinkGeo.MapSuite.FormsEdition.MapTool *ThinkGeo.MapSuite.FormsEdition.CenterCoordinateMapTool *ThinkGeo.MapSuite.FormsEdition.MapTool‹T› *ThinkGeo.MapSuite.FormsEdition.ZoomMapTool
MapTool | Initializes a new instance of the class. |
Adapter | MapElementAdapter | Gets the adapter. | |
IsEnabled | Boolean | Gets or sets a value indicating whether this instance is enabled. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
<!– ThinkGeo.MapSuite.FormsEdition.MapTool –> Go Back
