<!– Class –> This class represents the base class of map controls.
MapTool‹T› | Initializes a new instance of the class. |
Adapter | MapElementAdapter | MapTool | Gets the adapter. |
IsEnabled | Boolean | MapTool | Gets or sets a value indicating whether this instance is enabled. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
<!– ThinkGeo.MapSuite.FormsEdition.MapTool –> Go Back
