<!– Class –> This class represents the MapElementAdapter.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.AdornmentOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.BingMapsOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.CenterCoordinateMapToolApater *ThinkGeo.MapSuite.FormsEdition.Adapters.EditInteractiveOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.GoogleMapsOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.GpsMarkerAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.LayerOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolsAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapViewAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MarkerAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MarkerOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.OpenStreetMapOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.PopupAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.PopupOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.TileOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.TrackInteractiveOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.WmsOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.WorldMapKitOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.ZoomMapToolAdapter
MapElementAdapter | Initializes a new instance of the class. |
CreateConcrete | Creates the concrete. | ||
CreateConcreteCore | Creates the concrete core. | ||
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> |
Concrete | Object | Gets or sets the concrete. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
