<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the EditShape interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.EditInteractiveOverlayAdapter
EditInteractiveOverlayAdapter | Initializes a new instance of the class. |
CalculateAllControlPoints | This method calculates all control points. | ||
ClearAllControlPoints | This method clears all control points in corresponding layer. | ||
CreateConcrete | MapElementAdapter | Creates the concrete. | |
GetBoundingBox | OverlayAdapter | ||
Refresh | OverlayAdapter | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
CanDrag | Boolean | Gets a value which indicates whether the shape can be dragged. | |
CanReshape | Boolean | Gets a value which indicates whether the shape can be reshaped. | |
CanResize | Boolean | Gets a value which indicates whether the shape can be resized. | |
CanRotate | Boolean | Gets a value which indicates whether the shape can be rotated. | |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
EditShapesLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the edit shapes. | |
IsVisible | Boolean | OverlayAdapter | Gets or sets a value indicating whether this instance is visible. |
Name | String | OverlayAdapter | Gets or sets the name. |
First, it will clear all control points. Then it will calculate each control points according to their settings.
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.EditInteractiveOverlayAdapter –> Go Back
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
| InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –> |
