<!– Class –> This class is the base class of all overlay adapters in this overlay adapter system.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.AdornmentOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.BingMapsOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.EditInteractiveOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.GoogleMapsOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.LayerOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.MarkerOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.OpenStreetMapOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.PopupOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.TileOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.TrackInteractiveOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.WmsOverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.WorldMapKitOverlayAdapter
OverlayAdapter | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
GetBoundingBox | |||
Refresh | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | ||
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
IsVisible | Boolean | Gets or sets a value indicating whether this instance is visible. | |
Name | String | Gets or sets the name. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
