<!– Class –> This class represents an WmsOverlay which has MapSuite world map kit server integrated.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.TileOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.WorldMapKitOverlayAdapter
WorldMapKitOverlayAdapter | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
GetBoundingBox | OverlayAdapter | ||
Refresh | OverlayAdapter | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
ClientId | String | Gets or sets a value that is your Client Id. | |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
IsVisible | Boolean | OverlayAdapter | Gets or sets a value indicating whether this instance is visible. |
LayerType | WorldMapKitLayerType | Gets or sets the LayerType of the Overlay. | |
MapType | WorldMapKitMapType | Gets or sets the MapType of the Overlay. | |
Name | String | OverlayAdapter | Gets or sets the name. |
PrivateKey | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
Projection | WorldMapKitProjection | Gets or sets the projection for the this overlay. | |
TileCache | BitmapTileCache | TileOverlayAdapter | |
TimeoutInSeconds | Int32 | Gets or sets the length of time, in seconds, before the request times out. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.OverlayAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.WorldMapKitOverlayAdapter –> Go Back
| WorldMapKitLayerType<!– ThinkGeo.MapSuite.Core.WorldMapKitLayerType –> |
| WorldMapKitMapType<!– ThinkGeo.MapSuite.Core.WorldMapKitMapType –> |
This property needs work with map unit setting on the map object. All overlay adding to the map must keep the same unit or else the map won't display properly.
| WorldMapKitProjection<!– ThinkGeo.MapSuite.Core.WorldMapKitProjection –> |
| BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.TileOverlayAdapter –> Go Back
