<!– Class –> This class represents a control plugin
ControlPlugin | Initializes a new instance of the class. |
ApplySettings | StorableSettings | Plugin | Applies the settings to this plugin. |
GetSettings | Plugin | Gets plugin settings to save. | |
GetSettingsUI | Plugin | Gets an UI that configures settings. | |
GetUI | Gets the UI. | ||
Load | Plugin | This method raises when load this plugin. | |
ToString | Object | ||
Unload | Plugin | This method raises when unload this plugin. |
ApplySettingsCore | StorableSettings | Plugin | Applies the settings to this plugin. |
GetSettingsCore | Plugin | Gets plugin settings to save. | |
GetSettingsUICore | Plugin | Gets an UI that configures settings. | |
GetUICore | Gets the UI core. | ||
LoadCore | Plugin | This method raises when load this plugin. | |
MemberwiseClone | Object | ||
UnloadCore | Plugin | This method raises when unload this plugin. |
Author | String | Plugin | Gets or sets author information for plugin. |
Description | String | Plugin | Gets or sets description for plugin. |
Id | String | Plugin | Gets the identify of plugin. |
Index | Int32 | Plugin | Gets or sets the index of the plugin. |
IsActive | Boolean | Plugin | Gets or sets a value indicating whether this plugin is active. |
IsRequired | Boolean | Plugin | Gets or sets a value indicating whether this plugin is required. |
LargeIcon | ImageSource | Plugin | Gets or sets large icon for plugin. |
Name | String | Plugin | Gets or sets the name of plugin. |
SmallIcon | ImageSource | Plugin | Gets or sets small icon path for plugin. |
| settings | StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | The settings to be applied to this plugin. |
<!– ThinkGeo.MapSuite.GisEditor.Plugin –> Go Back
| StorableSettings<!– ThinkGeo.MapSuite.GisEditor.StorableSettings –> | Plugin's settings to save. |
| SettingUserControl<!– ThinkGeo.MapSuite.GisEditor.SettingUserControl –> | A SettingUserControl that configures settings. |
Gets the UI.
| FrameworkElement<!– System.Windows.FrameworkElement –> | The framework element |
<!– ThinkGeo.MapSuite.GisEditor.ControlPlugin –> Go Back
Gets the UI core.
Plugins are orded by this property.
Setting relative path to this property to discover image. Path should be like the form of FolderName(optional)/ImageFullName, such as “Images/NewContent.png” or “Content.png”. Make sure that image you supplied compiling with Build Action Resource.
| ImageSource<!– System.Windows.Media.ImageSource –> |
