thinkgeo.mapsuite.formsedition.adapters.markeradapter
ThinkGeo.MapSuite.FormsEdition.Adapters.MarkerAdapter
<!– Class –> Represents a marker control on the map.
Options for scaling the bounds of an image to the bounds of this view. Documentation
Protected MethodMarkerAdapter Initializes a new instance of the class.
Public MethodCreateConcrete MapElementAdapter Creates the concrete.
Public MethodGetType Object
Public MethodToString Object
Protected MethodCreateConcreteCore MapElementAdapter Creates the concrete core.
Protected MethodOnClick EventArgs Handles the event.
Protected MethodRegisterCollectionSynchronization GeoCollection<FormsItem>, GeoCollection<ConcreteItem> MapElementAdapter
Public PropertyConcrete Object MapElementAdapter Gets or sets the concrete.
Public PropertyImageSource String Gets or sets the image source.
Public PropertyPosition PointShape World Position of marker. It's a wrapper of the PositionProperty.
Public PropertyXOffset Int32 Gets or sets the x offset.
Public PropertyYOffset Int32 Gets or sets the y offset.
Public EventClick EventArgs Occurs when click.
MarkerAdapter()
Name Type Description
Go Back
CreateConcrete()
Return Type Description
Object<!– System.Object –> System.Object.
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
CreateConcreteCore()
Void<!– System.Void –>
OnClick(EventArgs)
Handles the event.
e EventArgs<!– System.EventArgs –> The instance containing the event data.
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MarkerAdapter –> Go Back
RegisterCollectionSynchronization(GeoCollection<FormsItem>, GeoCollection<ConcreteItem>)
formsItems GeoCollection<FormsItem><!– GeoCollection{FormsItem} –>
concreteItems GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –>
Concrete
Return Type
ImageSource
Return Type
Position
Return Type
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –>
XOffset
Return Type
YOffset
Return Type
Click
Occurs when click.
Event Arguments
Event Arguments
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition.Adapters UpdateDocumentation
thinkgeo.mapsuite.formsedition.adapters.markeradapter.txt · Last modified: 2017/03/16 21:59 (external edit)
