<!– Class –>
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.GpsMarkerAdapter
GpsMarkerAdapter | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
OnClick | EventArgs | Handles the event. | |
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
HaloRadiusInMeter | Single | ||
ImageSource | String | Gets or sets the image source. | |
Position | PointShape | World Position of marker. It's a wrapper of the PositionProperty. | |
XOffset | Int32 | Gets or sets the x offset. | |
YOffset | Int32 | Gets or sets the y offset. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
Handles the event.
| e | EventArgs<!– System.EventArgs –> | The instance containing the event data. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.GpsMarkerAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
| PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
Occurs when click.
| Event Arguments |
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition.Adapters UpdateDocumentation
