<!– Class –> The adapter represents the coordinates of the map center, display in the lower right corner of the map.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.CenterCoordinateMapToolApater
CenterCoordinateMapToolApater | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
DisplayProjection | Proj4Projection | Gets or sets the display projection. | |
DisplayTextFormat | String | Gets or sets the display text format. | |
IsEnabled | Boolean | MapToolAdapter | Gets or sets a value indicating whether this instance is enabled. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
| Proj4Projection<!– ThinkGeo.MapSuite.Core.Proj4Projection –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.CenterCoordinateMapToolApater –> Go Back
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter –> Go Back
