thinkgeo.mapsuite.formsedition.adapters.maptooladapter
ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter
<!– Class –> This class represents the base class maptool adapter.
Protected MethodMapToolAdapter Initializes a new instance of the class.
Public MethodCreateConcrete MapElementAdapter Creates the concrete.
Public MethodGetType Object
Public MethodToString Object
Protected MethodCreateConcreteCore MapElementAdapter Creates the concrete core.
Protected MethodRegisterCollectionSynchronization GeoCollection<FormsItem>, GeoCollection<ConcreteItem> MapElementAdapter
Public PropertyConcrete Object MapElementAdapter Gets or sets the concrete.
Public PropertyIsEnabled Boolean Gets or sets a value indicating whether this instance is enabled.
MapToolAdapter()
Name Type Description
Go Back
CreateConcrete()
Return Type Description
Object<!– System.Object –> System.Object.
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
CreateConcreteCore()
Void<!– System.Void –>
RegisterCollectionSynchronization(GeoCollection<FormsItem>, GeoCollection<ConcreteItem>)
formsItems GeoCollection<FormsItem><!– GeoCollection{FormsItem} –>
concreteItems GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –>
Concrete
Return Type
IsEnabled
Return Type
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter –> Go Back
thinkgeo.mapsuite.formsedition.adapters.maptooladapter.txt · Last modified: 2017/03/16 21:59 (external edit)
