<!– Class –> The Aadpter contains the different map tools as properties and acts as an entrance for setting these map controls.
This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolsAdapter
MapToolsAdapter | Initializes a new instance of the class. | ||
MapToolsAdapter | Object | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
Refresh | Refreshes all the map tools objects maintaining in the MapTools object. | ||
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
CenterCoordinateAdapter | CenterCoordinateMapToolApater | Gets the center coordinate adapter. | |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
ZoomMapToolAdapter | ZoomMapToolAdapter | Gets the zoom map tool adapter. |
| concrete | Object<!– System.Object –> | The concrete. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolsAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
| CenterCoordinateMapToolApater<!– ThinkGeo.MapSuite.FormsEdition.Adapters.CenterCoordinateMapToolApater –> |
| ZoomMapToolAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.ZoomMapToolAdapter –> |
