<!– Class –> Provides data for the VertexAdded. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.VertexAddedTrackInteractiveOverlayEventArgs
|  VertexAddedTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
|  VertexAddedTrackInteractiveOverlayEventArgs | Vertex, Feature | This is the commonly used constructor. |
|  Equals | Object | Object | |
|  GetHashCode | Object | ||
|  GetType | Object | ||
|  ToString | Object |
|  Finalize | Object | ||
|  MemberwiseClone | Object |
|  AddedVertex | Vertex | This property gets or sets the vertex added. | |
|  AffectedFeature | Feature | This property gets or sets the Feature with vertex added. |
| Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> |
<!– ThinkGeo.MapSuite.FormsEdition.VertexAddedTrackInteractiveOverlayEventArgs –> Go Back
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
