<!– Class –> Represents the zooming panel in the upper left corner of the map.
The zoom map tool consists of two zooming buttons.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter ThinkGeo.MapSuite.FormsEdition.Adapters.ZoomMapToolAdapter
ZoomMapToolAdapter | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
GlobeExtent | RectangleShape | Gets or sets the globe extent. | |
IsEnabled | Boolean | MapToolAdapter | Gets or sets a value indicating whether this instance is enabled. |
IsGlobeButtonVisiable | Boolean | Gets or sets a value indicating whether this instance is globe button visiable. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.ZoomMapToolAdapter –> Go Back
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolAdapter –> Go Back
