thinkgeo.mapsuite.iosedition.trackstartedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.TrackStartedTrackInteractiveOverlayEventArgs
Provides data for the TrackStarted. event.
      • ThinkGeo.MapSuite.iOSEdition.TrackStartedTrackInteractiveOverlayEventArgs
TrackStartedTrackInteractiveOverlayEventArgs()
TrackStartedTrackInteractiveOverlayEventArgs(Vertex)
  • startedVertex
    • Type:Vertex
    • Description:This parameter specified the started vertex when tracking shape action is started.
StartedVertex
This property gets or sets the started vertex when tracking shape action is started.
thinkgeo.mapsuite.iosedition.trackstartedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
