This enumeration defines the different labeling duplicate rules.
Duplicate refers to the condition where a label's text is exactly the same as another label. An example case where this is common is a road where each intersection is its own segment. In such a case, you do not want to label each segment as it would be highly redundant.
OneDuplicateLabelPerQuadrant
NoDuplicateLabels
UnlimitedDuplicateLabels
