<!– Class –> Class MapViewAdapter.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.MapViewAdapter
MapViewAdapter | Initializes a new instance of the class. |
CenterAt | PointShape | Locates the map center to the specified world point. | |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
Dispose | Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources. | ||
Refresh | This method will simulate the Refresh interaction. Refreshes current map control. | ||
ToString | Object | ||
ZoomTo | PointShape, Double | This method zooms current map to a specified position and scale. | |
ZoomTo | BaseShape | This method zooms current map to the target shape. | |
ZoomToNextExtent | Zooms to next extent. | ||
ZoomToPreviousExtent | Zooms to previous extent. | ||
ZoomToScale | Double | Zooms the map to a provided scale. This method will simulate the ZoomToScale interaction. |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
Dispose | Boolean | Releases unmanaged and - optionally - managed resources. | |
Finalize | Object(overriden) | ||
MemberwiseClone | Object | ||
OnCurrentExtentChanged | CurrentExtentChangedMapViewEventArgs | Handles the event. | |
OnCurrentExtentChanging | CurrentExtentChangingMapViewEventArgs | Handles the event. | |
OnCurrentScaleChanged | CurrentScaleChangedMapViewEventArgs | Handles the event. | |
OnCurrentScaleChanging | CurrentScaleChangingMapViewEventArgs | Handles the event. | |
OnMapDoubleTap | TouchMapViewEventArgs | Handles the event. | |
OnMapLongPress | TouchMapViewEventArgs | Handles the event. | |
OnMapSingleTap | TouchMapViewEventArgs | Handles the event. | |
OnMapTouchDown | TouchMapViewEventArgs | Handles the event. | |
OnMapTouchMove | TouchMapViewEventArgs | Handles the event. | |
OnMapTouchUp | TouchMapViewEventArgs | Handles the event. | |
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
AdornmentOverlayAdapter | AdornmentOverlayAdapter | Gets or sets the adornment overlay. | |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
CurrentExtent | RectangleShape | Gets or sets the current extent of the MapControl. | |
DisplayDensity | Single | Gets the display density. | |
EditOverlayAdapter | EditInteractiveOverlayAdapter | Gets the edit overlay adapter. | |
MapToolsAdapter | MapToolsAdapter | Gets the map tools adapter. | |
MapUnit | GeographyUnit | Gets or sets the map unit used by the MapControl. | |
Overlays | GeoCollection<Overlay> | This property gets the collection of Overlays in the MapControl. | |
TrackOverlayAdapter | TrackInteractiveOverlayAdapter | Gets the track overlay adapter. | |
ZoomLevelSet | ZoomLevelSet | This property gets or sets the ZoomLevelSet used for the MapView control. |
CurrentExtentChanged | CurrentExtentChangedMapViewEventArgs | Occurs when extent changed. | |
CurrentExtentChanging | CurrentExtentChangingMapViewEventArgs | Occurs when extent changing. | |
CurrentScaleChanged | CurrentScaleChangedMapViewEventArgs | Occurs when scale changed. | |
CurrentScaleChanging | CurrentScaleChangingMapViewEventArgs | Occurs when scale changing. | |
MapDoubleTap | TouchMapViewEventArgs | Occurs when double tap. | |
MapLongPress | TouchMapViewEventArgs | Occurs when long press. | |
MapSingleTap | TouchMapViewEventArgs | Occurs when single tap. | |
MapTouchDown | TouchMapViewEventArgs | Occurs when touch down. | |
MapTouchMove | TouchMapViewEventArgs | Occurs when touch move. | |
MapTouchUp | TouchMapViewEventArgs | Occurs when touch up. |
| worldCenter | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A world point to locate the map. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapViewAdapter –> Go Back
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
Refreshes all the existing overlays and map tools.
When calling this method, it doesn't refresh existing Tiles on the current map. For example, if using a TileOverlay such as LayerOverlay; a layer style is changed, Refresh method is proper to call.
| worldCenter | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | |
| targetScale | Double<!– System.Double –> | A double value indicates the scale to zoom the map to. |
| targetExtent | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | A ractangle shape to locates the map. |
| targetScale | Double<!– System.Double –> | A target scale to zoom the map. |
| disposing | Boolean<!– System.Boolean –> | true to release both managed and unmanaged resources; false to release only unmanaged resources. |
Handles the event.
| e | CurrentExtentChangedMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangedMapViewEventArgs –> | The instance containing the event data. |
Handles the event.
| e | CurrentExtentChangingMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangingMapViewEventArgs –> | The instance containing the event data. |
Handles the event.
| e | CurrentScaleChangedMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangedMapViewEventArgs –> | The instance containing the event data. |
Handles the event.
| e | CurrentScaleChangingMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangingMapViewEventArgs –> | The instance containing the event data. |
Handles the event.
| e | TouchMapViewEventArgs<!– ThinkGeo.MapSuite.FormsEdition.TouchMapViewEventArgs –> | The instance containing the event data. |
Handles the event.
Handles the event.
Handles the event.
Handles the event.
Handles the event.
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
| AdornmentOverlayAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.AdornmentOverlayAdapter –> |
The current extent stands for the extent of current position, this is very important metrics to caculate the scale.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> |
| EditInteractiveOverlayAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.EditInteractiveOverlayAdapter –> |
| MapToolsAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapToolsAdapter –> |
The MapUnit reflects the data unit.
| GeoCollection<Overlay><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.FormsEdition.Overlay} –> |
| TrackInteractiveOverlayAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.TrackInteractiveOverlayAdapter –> |
| ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition.Adapters UpdateDocumentation
