<!– Class –> Use to send data when map's extent is changed.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangedMapViewEventArgs
CurrentExtentChangedMapViewEventArgs | Initializes a new instance of the class. | ||
CurrentExtentChangedMapViewEventArgs | RectangleShape, RectangleShape | Initializes a new instance of the class. |
CurrentExtent | RectangleShape | Gets or sets the current extent. | |
PreviousExtent | RectangleShape | Gets or sets the previous extent. |
| previousExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The previous extent. |
| currentExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The current extent. |
<!– ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangedMapViewEventArgs –> Go Back
