<!– Class –> Use to send data when map's current scale is changing.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangingMapViewEventArgs
CurrentScaleChangingMapViewEventArgs | |||
CurrentScaleChangingMapViewEventArgs | Double, Double | Initializes a new instance of the class. |
CurrentScale | Double | Gets or sets the current scale. | |
PreviousScale | Double | Gets or sets the previous scale. |
| previousScale | Double<!– System.Double –> | The previous scale. |
| currentScale | Double<!– System.Double –> | The current scale. |
<!– ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangingMapViewEventArgs –> Go Back
