<!– Class –> This class is the base class of all overlays in this overlay system.
The <strong>Overlay</strong> has the similar concept as the layer. Different types of overlays stack over each other to form a map. An overlay object is responsible for getting the configuration infomation from the user.
Usually an overlay represents an image with transparent background that is laid upon other overlay such as <strong>LayerOverlay</strong>, <strong>WmsOverlay</strong>. While the <strong>MarkerOverlay</strong> will not be rendered as an image, it is actually represents a control that holds bunch of marker images on the map.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay *ThinkGeo.MapSuite.FormsEdition.AdornmentOverlay *ThinkGeo.MapSuite.FormsEdition.BingMapsOverlay *ThinkGeo.MapSuite.FormsEdition.EditInteractiveOverlay *ThinkGeo.MapSuite.FormsEdition.GoogleMapsOverlay *ThinkGeo.MapSuite.FormsEdition.InteractiveOverlay *ThinkGeo.MapSuite.FormsEdition.LayerOverlay *ThinkGeo.MapSuite.FormsEdition.MarkerOverlay *ThinkGeo.MapSuite.FormsEdition.OpenStreetMapOverlay *ThinkGeo.MapSuite.FormsEdition.Overlay‹T› *ThinkGeo.MapSuite.FormsEdition.PopupOverlay *ThinkGeo.MapSuite.FormsEdition.TileOverlay *ThinkGeo.MapSuite.FormsEdition.TileOverlay‹T› *ThinkGeo.MapSuite.FormsEdition.TrackInteractiveOverlay *ThinkGeo.MapSuite.FormsEdition.WmsOverlay *ThinkGeo.MapSuite.FormsEdition.WorldMapKitOverlay
Overlay | Initializes a new instance of the class. |
GetBoundingBox | Gets the bounding box. | ||
Refresh | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | ||
Adapter | MapElementAdapter | Gets the adapter. | |
IsVisible | Boolean | Gets or sets a value indicating whether this instance is visible. | |
Name | String | Gets or sets the name. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
