thinkgeo.mapsuite.formsedition.overlay_t
ThinkGeo.MapSuite.FormsEdition.Overlay‹T›
<!– Class –> This class is the base class of all overlays in this overlay system.
The <strong>Overlay</strong> has the similar concept as the layer. Different types of overlays stack over each other to form a map. An overlay object is responsible for getting the configuration infomation from the user.
Usually an overlay represents an image with transparent background that is laid upon other overlay such as <strong>LayerOverlay</strong>, <strong>WmsOverlay</strong>. While the <strong>MarkerOverlay</strong> will not be rendered as an image, it is actually represents a control that holds bunch of marker images on the map.
Public MethodOverlay‹T› Initializes a new instance of the class.
Public MethodGetBoundingBox Overlay Gets the bounding box.
Public MethodGetType Object
Public MethodRefresh Overlay This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Public MethodToString Object
Public PropertyAdapter MapElementAdapter Overlay Gets the adapter.
Public PropertyIsVisible Boolean Overlay Gets or sets a value indicating whether this instance is visible.
Public PropertyName String Overlay Gets or sets the name.
Overlay‹T›()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> RectangleShape.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Refresh()
Void<!– System.Void –>
String<!– System.String –>
Adapter
Gets the adapter.
Return Type
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –>
IsVisible
Return Type
Return Type
thinkgeo.mapsuite.formsedition.overlay_t.txt · Last modified: 2017/03/16 21:59 (external edit)
