This enumation provides the options used to set the ZoomLevel Snapping Mode. In SnapUp or Default mode, there are only 20 preset ZoomLevels whose scales are set accordingly with OpenLayers' scales. You can change this by setting the SnappingMode to None, but in doing so, you will lose the ability to use the TileCache system.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.ZoomLevelSnappingMode
Default
SnapUp
