<!– Class –>
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay * PublicKeyToken=null]] * Culture=neutral * Version=9.0.0.0 MapSuiteFormsEdition *ThinkGeo.MapSuite.FormsEdition.Overlay‹T›[[ThinkGeo.MapSuite.FormsEdition.Adapters.AdornmentOverlayAdapter **ThinkGeo.MapSuite.FormsEdition.AdornmentOverlay
AdornmentOverlay | |||
AdornmentOverlay | AdornmentOverlayAdapter |
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
Adapter | MapElementAdapter | Overlay | Gets the adapter. |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
Layers | GeoCollection<AdornmentLayer> | ||
Name | String | Overlay | Gets or sets the name. |
| adapter | AdornmentOverlayAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.AdornmentOverlayAdapter –> |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
| GeoCollection<AdornmentLayer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.AdornmentLayer} –> |
<!– ThinkGeo.MapSuite.FormsEdition.AdornmentOverlay –> Go Back
