<!– Class –> This class represents an overlay that requesting images from OpenStreet Map Service.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay *ThinkGeo.MapSuite.FormsEdition.TileOverlay
* Culture=neutral Version=9.0.0.0 * MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition.TileOverlay‹T›[[ThinkGeo.MapSuite.FormsEdition.Adapters.OpenStreetMapOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.OpenStreetMapOverlay
OpenStreetMapOverlay | Initializes a new instance of the class. |
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
Adapter | MapElementAdapter | Overlay | Gets the adapter. |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
Name | String | Overlay | Gets or sets the name. |
TileCache | BitmapTileCache | TileOverlay |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
| BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
<!– ThinkGeo.MapSuite.FormsEdition.TileOverlay –> Go Back
