<!– Class –> This class represents an WmsOverlay which has MapSuite world map kit server integrated.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay *ThinkGeo.MapSuite.FormsEdition.TileOverlay
* Culture=neutral Version=9.0.0.0 * MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition.TileOverlay‹T›[[ThinkGeo.MapSuite.FormsEdition.Adapters.WorldMapKitOverlayAdapter *ThinkGeo.MapSuite.FormsEdition.WorldMapKitOverlay
WorldMapKitOverlay | Initializes a new instance of the class. |
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
Adapter | MapElementAdapter | Overlay | Gets the adapter. |
ClientId | String | Gets or sets a value that is your Client Id. | |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
LayerType | WorldMapKitLayerType | Gets or sets the LayerType of the Overlay. | |
MapType | WorldMapKitMapType | ||
Name | String | Overlay | Gets or sets the name. |
PrivateKey | String | Gets or sets a value that is unique to your client ID, please keep your key secure. | |
Projection | WorldMapKitProjection | Gets or sets the projection for the this overlay. | |
TileCache | BitmapTileCache | TileOverlay | |
TimeoutInSeconds | Int32 | Gets or sets the length of time, in seconds, before the request times out. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
<!– ThinkGeo.MapSuite.FormsEdition.WorldMapKitOverlay –> Go Back
| WorldMapKitLayerType<!– ThinkGeo.MapSuite.Core.WorldMapKitLayerType –> |
| WorldMapKitMapType<!– ThinkGeo.MapSuite.Core.WorldMapKitMapType –> |
This property needs work with map unit setting on the map object. All overlay adding to the map must keep the same unit or else the map won't display properly.
| WorldMapKitProjection<!– ThinkGeo.MapSuite.Core.WorldMapKitProjection –> |
| BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –> |
<!– ThinkGeo.MapSuite.FormsEdition.TileOverlay –> Go Back
