thinkgeo.mapsuite.formsedition.markeroverlay
ThinkGeo.MapSuite.FormsEdition.MarkerOverlay
<!– Class –> This class represents an overlay which maintaining markers.
Public MethodMarkerOverlay Initializes a new instance of the class.
Public MethodGetBoundingBox Overlay Gets the bounding box.
Public MethodGetType Object
Public MethodRefresh Overlay This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Public MethodToString Object
Public PropertyAdapter MapElementAdapter Overlay Gets the adapter.
Public PropertyIsVisible Boolean Overlay Gets or sets a value indicating whether this instance is visible.
Public PropertyMarkers GeoCollection<Marker> A collection that holds all the marker objects adding in the overlay.
Public PropertyName String Overlay Gets or sets the name.
MarkerOverlay()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> RectangleShape.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Refresh()
Void<!– System.Void –>
String<!– System.String –>
Adapter
Gets the adapter.
Return Type
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –>
IsVisible
Return Type
Markers
Return Type
GeoCollection<Marker><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.FormsEdition.Marker} –>
<!– ThinkGeo.MapSuite.FormsEdition.MarkerOverlay –> Go Back
Return Type
thinkgeo.mapsuite.formsedition.markeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
