<!– Class –> Represents a marker control on the map.
Options for scaling the bounds of an image to the bounds of this view. Documentation
Marker | Initializes a new instance of the class. |
MemberwiseClone | Object | ||
OnClick | EventArgs | Handles the event. |
Adapter | MapElementAdapter | Gets the adapter. | |
ImageSource | String | Gets or sets the image source. | |
Position | PointShape | World Position of marker. It's a wrapper of the PositionProperty. | |
XOffset | Int32 | Gets or sets the x offset of marker image. | |
YOffset | Int32 | Gets or sets the y offset of marker image. |
Name | Type | Description |
Return Type | Description |
Int32<!– System.Int32 –> |
Type<!– System.Type –> |
String<!– System.String –> |
Void<!– System.Void –> |
Handles the event.
e | EventArgs<!– System.EventArgs –> | The instance containing the event data. |
<!– ThinkGeo.MapSuite.FormsEdition.Marker –> Go Back
Gets the adapter.
Return Type |
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
Return Type |
Return Type |
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
Return Type |
Return Type |
Occurs when click.
Event Arguments |
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
