<!– Class –> This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay *ThinkGeo.MapSuite.FormsEdition.InteractiveOverlay ThinkGeo.MapSuite.FormsEdition.EditInteractiveOverlay ThinkGeo.MapSuite.FormsEdition.TrackInteractiveOverlay
InteractiveOverlay | Default constructor of this abstract class. |
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
Gets or sets a value indicating whether this instance is visible.
Gets or sets the name.
