<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the EditShape interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay *ThinkGeo.MapSuite.FormsEdition.InteractiveOverlay ThinkGeo.MapSuite.FormsEdition.EditInteractiveOverlay
EditInteractiveOverlay | Default constructor of the class. If you use thi constructor, please set the properties correctly or it will use their default values. | ||
EditInteractiveOverlay | EditInteractiveOverlayAdapter | Default constructor of the class. If you use thi constructor, please set the properties correctly or it will use their default values. |
CalculateAllControlPoints | This method calculates all control points. | ||
ClearAllControlPoints | This method clears all control points in corresponding layer. | ||
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
Adapter | MapElementAdapter | Overlay | Gets the adapter. |
CanDrag | Boolean | Gets a value which indicates whether the shape can be dragged. | |
CanReshape | Boolean | Gets a value which indicates whether the shape can be reshaped. | |
CanResize | Boolean | Gets a value which indicates whether the shape can be resized. | |
CanRotate | Boolean | Gets a value which indicates whether the shape can be rotated. | |
EditShapesLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the edit shapes. | |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
Name | String | Overlay | Gets or sets the name. |
| adapter | EditInteractiveOverlayAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.EditInteractiveOverlayAdapter –> | Represents interactiveOverlay adapter. |
First, it will clear all control points. Then it will calculate each control points according to their settings.
<!– ThinkGeo.MapSuite.FormsEdition.EditInteractiveOverlay –> Go Back
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
| InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –> |
