map_suite_core_deployment_guide_deploying_applications
Map Suite Core Deployment Guide Deploying Applications
Several Merge Modules are supplied to assist you in deploying all of our required dependencies. You can find then in the directory below.
  • \Developer Reference\Merge Module\MapSuiteEcwX64.msm
  • \Developer Reference\Merge Module\MapSuiteEcwX86.msm
  • \Developer Reference\Merge Module\MapSuiteGeoTiffX64.msm
  • \Developer Reference\Merge Module\MapSuiteGeoTiffX86.msm
  • \Developer Reference\Merge Module\MapSuiteMrSidX64.msm
  • \Developer Reference\Merge Module\MapSuiteMrSidX86.msm
  • \Developer Reference\Merge Module\MapSuitePrjHelperX64.msm
  • \Developer Reference\Merge Module\MapSuitePrjHelperX86.msm
  • \Developer Reference\Merge Module\MapSuiteProj4ProjectionX64.msm
  • \Developer Reference\Merge Module\MapSuiteProj4ProjectionX86.msm
  • \Developer Reference\Merge Module\VC_User_CRT71_RTL_X86_—.msm
  • \Developer Reference\Merge Module\VC_User_STL71_RTL_X86_—.msm
  • \Developer Reference\Merge Module\MicrosoftSqlServerSpatialX86.msm*
  • \Developer Reference\Merge Module\MicrosoftSqlServerSpatialX64.msm*
  • \Developer Reference\Merge Module\Microsoft_VC100_CRT_x64.msm*
  • \Developer Reference\Merge Module\Microsoft_VC100_CRT_x86.msm*
Note: The main assemblies of MapSuiteCore.DLL , NetTopologySuite.DLL GeoAPI.dll are not included in the Merge Modules, your project should automatically reference them and pull in these assemblies.
MicrosoftSqlServerSpatialX86.msm and MicrosoftSqlServerSpatialX64.msm are always required.
MapSuiteGeoTiffX64.msm and MapSuiteGeoTiffX86.msm are not required if the GeoTiffRasterSource's LibraryType is ManagedLibTiff(By Default).
MapSuiteProj4ProjectionX64.msm and MapSuiteProj4ProjectionX86.msm are not required if Proj4Projection's MemoryMode is ManagedProj4Projection(By Default).
map_suite_core_deployment_guide_deploying_applications.txt · Last modified: 2015/09/21 01:56 by admin
