<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay *ThinkGeo.MapSuite.FormsEdition.InteractiveOverlay ThinkGeo.MapSuite.FormsEdition.TrackInteractiveOverlay
TrackInteractiveOverlay | Initializes a new instance of the class. | ||
TrackInteractiveOverlay | TrackInteractiveOverlayAdapter | Initializes a new instance of the class. |
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
MemberwiseClone | Object | ||
OnMouseMoved | MouseMovedTrackInteractiveOverlayEventArgs | Handles the event. | |
OnTrackEnded | TrackEndedTrackInteractiveOverlayEventArgs | Handles the event. | |
OnTrackEnding | TrackEndingTrackInteractiveOverlayEventArgs | Handles the event. | |
OnTrackStarted | TrackStartedTrackInteractiveOverlayEventArgs | Handles the event. | |
OnTrackStarting | TrackStartingTrackInteractiveOverlayEventArgs | Handles the event. | |
OnVertexAdded | VertexAddedTrackInteractiveOverlayEventArgs | Handles the event. | |
OnVertexAdding | VertexAddingTrackInteractiveOverlayEventArgs | Handles the event. |
Adapter | MapElementAdapter | Overlay | Gets the adapter. |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
Name | String | Overlay | Gets or sets the name. |
TrackMode | TrackMode | Gets a mode of TrackOverlay. | |
TrackShapeLayer | InMemoryFeatureLayer | This property gets the TrackShape layers which holds the track shapes. |
MouseMoved | MouseMovedTrackInteractiveOverlayEventArgs | This event will be fired when mouse moved on the vertex of tracking shape. | |
TrackEnded | TrackEndedTrackInteractiveOverlayEventArgs | This event will be fired after the end of tracking shape. | |
TrackEnding | TrackEndingTrackInteractiveOverlayEventArgs | This event will be fired before the end of tracking shape. | |
TrackStarted | TrackStartedTrackInteractiveOverlayEventArgs | This event will be fired after the start of tracking shape. | |
TrackStarting | TrackStartingTrackInteractiveOverlayEventArgs | This event will be fired before the start of tracking shape. | |
VertexAdded | VertexAddedTrackInteractiveOverlayEventArgs | This event will be fired after a vertex added to the tracking shape. | |
VertexAdding | VertexAddingTrackInteractiveOverlayEventArgs | This event will be fired before a vertex added to the tracking shape. |
| adapter | TrackInteractiveOverlayAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.TrackInteractiveOverlayAdapter –> | Represents interactiveOverlay adapter. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Handles the event.
| e | MouseMovedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.MouseMovedTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
<!– ThinkGeo.MapSuite.FormsEdition.TrackInteractiveOverlay –> Go Back
Handles the event.
| e | TrackEndedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.TrackEndedTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| e | TrackEndingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.TrackEndingTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| e | TrackStartedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.TrackStartedTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| e | TrackStartingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.TrackStartingTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| e | VertexAddedTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.VertexAddedTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
Handles the event.
| e | VertexAddingTrackInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.FormsEdition.VertexAddingTrackInteractiveOverlayEventArgs –> | The instance containing the event data. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
The default mode is TrackMode.None which means you cannot draw or edit features at client. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you could add point, line or polygon to the FeatureOverlay. Setting the mode to TrackMode.Edit, you could edit the shapes at the client side.
| TrackMode<!– ThinkGeo.MapSuite.FormsEdition.TrackMode –> |
| InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –> |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
| Event Arguments |
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
