<!– Class –> Provides data for the TrackStarted. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.TrackStartedTrackInteractiveOverlayEventArgs
TrackStartedTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
TrackStartedTrackInteractiveOverlayEventArgs | Vertex | This is the commonly used constructor. |
StartedVertex | Vertex | This property gets or sets the started vertex when tracking shape action is started. |
| startedVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specified the started vertex when tracking shape action is started. |
<!– ThinkGeo.MapSuite.FormsEdition.TrackStartedTrackInteractiveOverlayEventArgs –> Go Back
