<!– Enumeration –> Enum TrackMode
| Name | Summary |
| None | Default mode. |
| Point | Draw point mode. |
| Line | Draw line mode. |
| Polygon | Draw polygon mode. |
| Rectangle | Draw rectangle mode. |
| Square | Draw square mode. |
| Circle | Draw circle mode. |
| Ellipse | Draw ellipse mode. |
| StraightLine | Allows user to draw a simple line with only 2 points on the map. |
| Freehand | Allows user to draw freehand on the map |
| Custom | Allows user to draw custom trackshape on the map |
