<!– Class –> Provides data for the TrackEnding. event.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.TrackEndingTrackInteractiveOverlayEventArgs
TrackEndingTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. | ||
TrackEndingTrackInteractiveOverlayEventArgs | BaseShape, Boolean | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets the action to be canceled or not. | |
TrackShape | BaseShape | This property gets or sets the shape to be tracking out. |
| shape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter specified the shape to be tracking out. |
| cancel | Boolean<!– System.Boolean –> | This parameter specified the cancel property. |
<!– ThinkGeo.MapSuite.FormsEdition.TrackEndingTrackInteractiveOverlayEventArgs –> Go Back
