<!– Class –> This is the default constructor of this parameter.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.TrackEndedTrackInteractiveOverlayEventArgs
TrackEndedTrackInteractiveOverlayEventArgs | This is the commonly used constructor. | ||
TrackEndedTrackInteractiveOverlayEventArgs | BaseShape | This is the commonly used constructor. |
Cancel | Boolean | This property gets or sets the action to be canceled or not. This property has no use any more, please use the it in the TrackInteractiveOverlay.TrackEnding event. | |
TrackShape | BaseShape | This property gets or sets the tracked shape. |
| trackShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter specified the tracked shape. |
<!– ThinkGeo.MapSuite.FormsEdition.TrackEndedTrackInteractiveOverlayEventArgs –> Go Back
