thinkgeo.mapsuite.desktopedition.trackstartedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs
Provides data for the TrackStarted event.
      • ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs
TrackStartedTrackInteractiveOverlayEventArgs()
  • If you use this constructor, you must set the properties manually before use.
TrackStartedTrackInteractiveOverlayEventArgs(Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#TrackStartedTrackInteractiveOverlayEventArgs.28Vertex.29
  • startedVertex
    • Type:Vertex
    • Description:This parameter specifies the start vertex once the tracking shape action has been started.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.TrackStartedTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29
StartedVertex
  • This property gets or sets the start vertex when the tracking shape action has been started.
thinkgeo.mapsuite.desktopedition.trackstartedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
