<!– Class –> Represents an overlay object that gets map images from the WMS server you specify.
The <strong>WmsOverlay</strong> gets images from one or more WMS servers that you specify. Usually, you add a WMS server URI to the <strong>ServerUris</strong> collection and the <strong>WmsOverlay</strong> will make a request to that WMS server to get its tile images.
You can also add multiple WMS server URIs to the ServerUris collection. The WmsOverlay will randomly send requests to those WMS servers in a concurrent fashion. This means that the tile images can come from different WMS servers, thus greatly enhancing performance. <strong>Do not</strong> add URIs of differently-configured WMS servers to the ServerUris collection.
*System.Object ThinkGeo.MapSuite.FormsEdition.Overlay * PublicKeyToken=null]] * Culture=neutral * Version=9.0.0.0 MapSuiteFormsEdition *ThinkGeo.MapSuite.FormsEdition.Overlay‹T›[[ThinkGeo.MapSuite.FormsEdition.Adapters.WmsOverlayAdapter **ThinkGeo.MapSuite.FormsEdition.WmsOverlay
WmsOverlay | Initializes a new instance of the class. |
GetBoundingBox | Overlay | Gets the bounding box. | |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
Adapter | MapElementAdapter | Overlay | Gets the adapter. |
IsVisible | Boolean | Overlay | Gets or sets a value indicating whether this instance is visible. |
Name | String | Overlay | Gets or sets the name. |
Parameters | Dictionary<String,String> | Gets a dictionary whose items will be passed to the WMS server as parameters. | |
ServerUris | Collection<Uri> | Gets a collection of URIs that specifies the locations of the WMS servers. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | RectangleShape. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
| Dictionary<String,String><!– System.Collections.Generic.Dictionary{System.String,System.String} –> |
<!– ThinkGeo.MapSuite.FormsEdition.WmsOverlay –> Go Back
| Collection<Uri><!– System.Collections.ObjectModel.Collection{System.Uri} –> |
