thinkgeo.mapsuite.formsedition.bingmapsoverlay
ThinkGeo.MapSuite.FormsEdition.BingMapsOverlay
<!– Class –> This class represents an overlay that requesting from Bing Maps Imagery Service.
Public MethodBingMapsOverlay Initializes a new instance of the class.
Public MethodGetBoundingBox Overlay Gets the bounding box.
Public MethodGetType Object
Public MethodRefresh Overlay This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Public MethodToString Object
Public PropertyAdapter MapElementAdapter Overlay Gets the adapter.
Public PropertyApplicationId String This property gets or sets an application account registered from Bing Maps Imagery Service.
Public PropertyIsVisible Boolean Overlay Gets or sets a value indicating whether this instance is visible.
Public PropertyMapStyle BingMapsMapType This property gets or sets the requesting map type from Bing Maps Imagery Service.
Public PropertyName String Overlay Gets or sets the name.
Public PropertyTileCache BitmapTileCache TileOverlay
BingMapsOverlay()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> RectangleShape.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Refresh()
Void<!– System.Void –>
String<!– System.String –>
Adapter
Gets the adapter.
Return Type
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –>
ApplicationId
Return Type
<!– ThinkGeo.MapSuite.FormsEdition.BingMapsOverlay –> Go Back
IsVisible
Return Type
MapStyle
Return Type
BingMapsMapType<!– ThinkGeo.MapSuite.Core.BingMapsMapType –>
Return Type
TileCache
Return Type
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –>
<!– ThinkGeo.MapSuite.FormsEdition.TileOverlay –> Go Back
thinkgeo.mapsuite.formsedition.bingmapsoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
