thinkgeo.mapsuite.wpfdesktopedition.drawtilesprogresschangedtileoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs
This method is the event args for download progress when requesting images in TileOverlay.
      • System.ComponentModel.ProgressChangedEventArgs
        • ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs
DrawTilesProgressChangedTileOverlayEventArgs()
  • Constructor of DrawTilesProgressChangedTileOverlayEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#DrawTilesProgressChangedTileOverlayEventArgs.28.29
DrawTilesProgressChangedTileOverlayEventArgs(Int32)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#DrawTilesProgressChangedTileOverlayEventArgs.28Int32.29
  • drawTilesPercentage
    • Description:An integar value indicates the download progress which is from 0 to 100.
DrawTilesProgressChangedTileOverlayEventArgs(Int32,Object)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#DrawTilesProgressChangedTileOverlayEventArgs.28Int32.2C_Object.29
  • userState
    • Description:A unique user state.
DrawTilesProgressChangedTileOverlayEventArgs(Int32,Object,TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#DrawTilesProgressChangedTileOverlayEventArgs.28Int32.2C_Object.2C_TimeSpan.29
  • userState
  • elapsedTime
    • Type:TimeSpan
    • Description:A integar value indicates the ellapsed time for all the completed tiles.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.DrawTilesProgressChangedTileOverlayEventArgs#MemberwiseClone.28.29
ElapsedTime
  • Type:TimeSpan
ProgressPercentage
UserState
thinkgeo.mapsuite.wpfdesktopedition.drawtilesprogresschangedtileoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
