thinkgeo.mapsuite.formsedition.layeroverlay
ThinkGeo.MapSuite.FormsEdition.LayerOverlay
<!– Class –> This class represents a group of layers; each layer can be of any layer type.
Public MethodLayerOverlay Initializes a new instance of the class.
Public MethodGetBoundingBox Overlay Gets the bounding box.
Public MethodGetType Object
Public MethodRefresh Overlay This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
Public MethodToString Object
Public PropertyAdapter MapElementAdapter Overlay Gets the adapter.
Public PropertyIsVisible Boolean Overlay Gets or sets a value indicating whether this instance is visible.
Public PropertyLayers GeoCollection<Layer> Gets a GeoCollection that contains the layers that will draw on the image.
Public PropertyName String Overlay Gets or sets the name.
Public PropertyTileCache BitmapTileCache TileOverlay
Public PropertyTileType TileType Gets and sets the overlay is formed by multiple tiles or single tile.
LayerOverlay()
Name Type Description
Go Back
Return Type Description
Boolean<!– System.Boolean –>
GetBoundingBox()
RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> RectangleShape.
Int32<!– System.Int32 –>
Type<!– System.Type –>
Refresh()
Void<!– System.Void –>
String<!– System.String –>
Adapter
Gets the adapter.
Return Type
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –>
IsVisible
Return Type
Layers
The <strong>Layers</strong> property holds all of the layers that are used by the <strong>Draw</strong> method. The Draw method loops through all layers to filter out features and draw on the image with the specified styles.
Return Type
GeoCollection<Layer><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Layer} –>
<!– ThinkGeo.MapSuite.FormsEdition.LayerOverlay –> Go Back
Return Type
TileCache
Return Type
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –>
<!– ThinkGeo.MapSuite.FormsEdition.TileOverlay –> Go Back
TileType
Return Type
TileType<!– ThinkGeo.MapSuite.FormsEdition.TileType –>
thinkgeo.mapsuite.formsedition.layeroverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
