<!– Class –> Use to send data when map's current scale is changed.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangedMapViewEventArgs
CurrentScaleChangedMapViewEventArgs | |||
CurrentScaleChangedMapViewEventArgs | Double, Double | Initializes a new instance of the class. |
CurrentScale | Double | Gets or sets the current scale. | |
PreviousScale | Double | Gets or sets the previous scale. |
| previousScale | Double<!– System.Double –> | The previous scale. |
| currentScale | Double<!– System.Double –> | The current scale. |
<!– ThinkGeo.MapSuite.FormsEdition.CurrentScaleChangedMapViewEventArgs –> Go Back
