<!– Class –> Use to send data when map's extent is changing.
*System.Object System.EventArgs *ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangingMapViewEventArgs
CurrentExtentChangingMapViewEventArgs | Initializes a new instance of the class. | ||
CurrentExtentChangingMapViewEventArgs | RectangleShape, RectangleShape | Initializes a new instance of the class. |
CurrentExent | RectangleShape | Gets or sets the current extent. | |
PreviousExtent | RectangleShape | Gets or sets the previous extent. |
| previousExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The previous extent. |
| currentExtent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The current extent. |
<!– ThinkGeo.MapSuite.FormsEdition.CurrentExtentChangingMapViewEventArgs –> Go Back
