<!– Class –> This class represents a popup control for placing on the map.
*System.Object ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter *ThinkGeo.MapSuite.FormsEdition.Adapters.PopupAdapter
PopupAdapter | Initializes a new instance of the class. |
CreateConcrete | MapElementAdapter | Creates the concrete. | |
CreateConcreteCore | MapElementAdapter | Creates the concrete core. | |
MemberwiseClone | Object | ||
RegisterCollectionSynchronization | GeoCollection<FormsItem>, GeoCollection<ConcreteItem> | MapElementAdapter |
Concrete | Object | MapElementAdapter | Gets or sets the concrete. |
Content | String | Gets or sets the content. | |
Position | PointShape | Gets and sets the position of the popup. | |
XOffset | Int32 | Gets or sets the x offset. | |
YOffset | Int32 | Gets or sets the y offset. |
| Object<!– System.Object –> | System.Object. |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> Go Back
| formsItems | GeoCollection<FormsItem><!– GeoCollection{FormsItem} –> | |
| concreteItems | GeoCollection<ConcreteItem><!– GeoCollection{ConcreteItem} –> |
<!– ThinkGeo.MapSuite.FormsEdition.Adapters.PopupAdapter –> Go Back
| PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
