<!– Class –> Represents the coordinates of the map center, display in the lower right corner of the map.
*System.Object ThinkGeo.MapSuite.FormsEdition.MapTool *ThinkGeo.MapSuite.FormsEdition.CenterCoordinateMapTool
CenterCoordinateMapTool | Initializes a new instance of the class. | ||
CenterCoordinateMapTool | CenterCoordinateMapToolApater | Initializes a new instance of the class. |
Adapter | MapElementAdapter | MapTool | Gets the adapter. |
DisplayProjection | Proj4Projection | Gets or sets the display projection. | |
DisplayTextFormat | String | Gets or sets the display text format. | |
IsEnabled | Boolean | MapTool | Gets or sets a value indicating whether this instance is enabled. |
| adapter | CenterCoordinateMapToolApater<!– ThinkGeo.MapSuite.FormsEdition.Adapters.CenterCoordinateMapToolApater –> | The adapter. |
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
<!– ThinkGeo.MapSuite.FormsEdition.MapTool –> Go Back
| Proj4Projection<!– ThinkGeo.MapSuite.Core.Proj4Projection –> |
<!– ThinkGeo.MapSuite.FormsEdition.CenterCoordinateMapTool –> Go Back
