thinkgeo.mapsuite.wpfdesktopedition.vertexmovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs
Provides data for the VertexMoving. event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs
VertexMovingEditInteractiveOverlayEventArgs()
  • Constructor of VertexMovingEditInteractiveOverlayEventArgs class.
VertexMovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29
  • cancel
    • Description:Indicates whether the operation is canceled or not.
  • affectedVertexFeature
    • Type:Feature
    • Description:Indicates a feature which is affected.
  • movingVertex
    • Type:Vertex
    • Description:Indicates a vertex which is moving.
VertexMovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex,PointShape)
  • Constructor of VertexMovedEditInteractiveOverlayEventArgs class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#VertexMovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.2C_PointShape.29
  • cancel
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movingVertex
    • Type:Vertex
    • Description:This parameter specified the moving vertex.
  • targetVertex
    • Description:This parameter specified the target vertex.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.VertexMovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
TargetVertex
Gets or sets the target vertex to be moved
AffectedVertexFeature
Gets or sets the Feature to be used to move vertex.
MovingVertex
Gets or sets the vertex to be moved.
Cancel
Gets or sets the action to be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.vertexmovingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
