thinkgeo.mapsuite.wpfdesktopedition.controlpointselectingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
      • ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs
ControlPointSelectingEditInteractiveOverlayEventArgs()
  • Constructor of ControlPointSelectingEditInteractiveOverlayEventArgs class.
ControlPointSelectingEditInteractiveOverlayEventArgs(Boolean,PointShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#ControlPointSelectingEditInteractiveOverlayEventArgs.28Boolean.2C_PointShape.29
  • cancel
  • targetPointShape
    • Description:This parameter specified the target control point to be selected.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.ControlPointSelectingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
TargetPointShape
Gets or sets the target control point to be selected.
Cancel
Gets or sets the action to be canceled or not.
thinkgeo.mapsuite.wpfdesktopedition.controlpointselectingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
