thinkgeo.mapsuite.wpfdesktopedition.mapmousedoubleclickinteractiveoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
Provides data for the MapMouseDoubleClick event.
      • ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseDoubleClickInteractiveOverlayEventArgs()
  • Constructor of MapMouseDoubleClickInteractiveOverlayEventArgs class.
MapMouseDoubleClickInteractiveOverlayEventArgs(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MapMouseDoubleClickInteractiveOverlayEventArgs.28InteractionArguments.29
  • interactionArguments
    • Description:This parameter specified the interaction auguments to construct the class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs#MemberwiseClone.28.29
This property gets the interaction auguments for the event args.
thinkgeo.mapsuite.wpfdesktopedition.mapmousedoubleclickinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
